nighthawkujzz's avatar
Sep 25, 2025
Nighthawk c7000 keeps on resetting wifi
I used nighthawk c7000v2 3 years back and then stored it up. I started using it again with Spectrum.
However the wifi keeps on resetting once a day. It can happen at any time of the day. I spoke with Spectrum and went through all the troubleshootinb and they confirmed the issue is not on their end.
Does anyone know how to fix this?
  • plemans's avatar
    Could be something either triggered by the ISP or just something corrupt in the settings. I'd do a hard reset by pushing and holding reset while powered on for up to 30 seconds. That should clear everything from memory. IF its a corrupt setting causing it, that should clear it out. If that doesn't help, it could be something hardware related causing the failure.
  • plemans's avatar
    How do you know the wifi is resetting?
    What do they logs show?
    • nighthawkujzz's avatar
      nighthawkujzz
      I use customized wifi username and password. Now and then, it resets to default. Also, the access to Router also resets to default username and password.
