Pat700
Aug 10, 2018Follower
Nighthawk C7000 parental control
Hi all, Apologies for a simple question - I am about to buy a Nigthawk C7000 so that I can add parental controls to my Virgin Media Hub 3.0. Apparently I can configure the hub 3.0 as a DOCSIS3 mode...
vkdelta
Aug 13, 2018NETGEAR Employee Retired
dont buy C7000 for Virgin Media. It will NOT work. it is not EURO DOCSIS certified.
you need to look for R7000P and connect behind Virgin SuperHub. Also change the superHub to MODEM MODE.
