Ryan_Hisle7
Mar 02, 2021Aspirant
Nighthawk C7000v2 Connection Dropping around every 30 minutes
So for the past 6 months, ever since I moved into my new apartment, the internet connection for all devices, ethernet and wifi, has dropped for anywhere from a few seconds to a few minutes every 30 minutes to an hour. The error code that appears in the Event Log of my router is "SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=44:a5:6e:80:a4:68;CMTS-MAC=00:56:2b:76:ce:af;CM-QOS=1.1;CM-VER=3.0;".
I don't know what causes this issue as I'm THIS tech savvy, but I doubt it's the integrity of my modem router combo, because it's only as old as August 2020, though if that's what is insisted is the issue then I won't debate it. I appreciate any time and help you guys put into this, thanks! Let me know if any more info is needed.
Also, my firmware version is V1.03.03, my internet plan is through xfinity, and I'm on the latest version of Windows 10.
- The issue has been resolved! The issue had nothing to do with any cables running to my room, through the apartment building, or from outside.
The issue was the tap on my floor of the building, the piece of equipment where all of the coax cables run to each apartment room! It was an older model, and Xfinity even noted that this model in particular has a tendency to turn off and back on randomly, which lines up with my issue. So for anyone having this problem in the future, if a tap is involved, investigate it on your journey of troubleshooting!
- Ryan_Hisle7Aspirant
do you also have a screen snip of the cable connections page?
- Ryan_Hisle7AspirantThe issue has been resolved! The issue had nothing to do with any cables running to my room, through the apartment building, or from outside.
