akeele's avatar
akeele
Star
Oct 26, 2021
NightHawk CAX 30 slows until Factory Reset or config restore
I have experienced this issue with this router since buying it at Costco in July 2021. My firmware is up-to-date with version 1.4.10.8. I do not have any special port forwarding or access control configured. This router does not support QoS configuration.
After initial setup, I get 350 - 500Mbps directly from the router over Xfinity that is provisioned for 400 Mbps. Within hours, the rate drops to 120 - 150 Mbps. This is consistent and repeatable.
I enabled Airtime Fairness. Nothing improved.
If I do a reboot, nothing is improved. This is consistent and repeatable.
If I do a hard factory reset, speed is temporarily restored in full. This is consistent and repeatable.
If I restore a backed-up configuration and then restore/overwrite + reboot, speed is temporarily restored in full. This is consistent and repeatable.
This router needs better firmware is all I can figure. I am not the only customer with this issue in this forum. I hope Netgear reads this post and will respond.
  • plemans's avatar
    How are you testing speeds?
    Wired?
    Wireless?
    Are you testing over the 2.4ghz or the 5ghz?
    What device are you testing on?
    • akeele's avatar
      akeele
      Star
      Per my original post, "After initial setup, I get 350 - 500Mbps directly from the router  over Xfinity that is provisioned for 400 Mbps. Within hours, the rate drops to 120 - 150 Mbps."
      I want to test the router's ability to handle what is provisioned. This means I logged into the router's Netgear administrative console to test internally from the router itself to avoid any potential network or wireless issues in getting to the router. I used the speed test tool on the router itself. As such, this test is neither wired nor wireless, and wireless frequency is not relevent.
      The device I'm testing on: directly from the router
      Here is a link on how to check the speed between your ISP and your router: https://kb.netgear.com/000038894/How-do-I-check-my-Internet-speed. This speed test should be fairly constant, and should not be influenced by resetting the router to factory defaults, or simply reloading the current config.
      • plemans's avatar
        "directly from the router" isn't always the best choice as it doesn't let you choose which server it tests off.
        And if it chooses a slower server, you get slower speeds showing even if they aren't accurate.
        its why if you look on here, you see us recommending people wire a pc/laptop into their router and test that route.
        Because then you can try different speedtest sites and even servers on those sites.
