BobatEP's avatar
BobatEP
Nighthawk CM1150
How do I unlock port #2 on the CM1150V  to connect my RedLINK  internet gateway to the internet?  I've hardwired the two devices and an amber light appears on port #2.  I believe the next step is to unlock the port so it will allow the connection.
  • I presume if you connect the other device on WAN port#1 as a test that it will work after the modem is rebooted?
    Hopefully your ISP can allow a 2nd WAN IP to the modem.
  • plemans's avatar
    Most ISP's only allow 1 device to be connected to a modem unless you're paying for extra public ip addresses or on a business class line.
    who's your isp?
    are you on a business class line or paying extra for more than 1 public ip address?
    • BobatEP's avatar
      BobatEP
      Comcast. I contacted them and they told me all 4 ports could be used.  Nest gear says only one at a time.
      • plemans's avatar
        Its not that comcast is lying to you but you might have talked to someone who didn't know exactly what was going on for your device or account.
        I have comcast and can confirm they only support 1 device connected at time on a standard line. If you pay for extra public IP addresses or a business class line, then you can connect extra.
  • FURRYe38's avatar
    What are you connected to Port#2? When you connect something to port #1 and #2, you need to either reboot the modem from the web page or power off the modem for 30 seconds then back on. If your ISP is allowing a WAN ip address to be assigned to the other ports, then the modem needs to reboot to make the change.
    • BobatEP's avatar
      BobatEP
      Tried rebooting, but it didn't solve the problem.  I will call Comcast support again to see if there is something else to try.
  • I've inquired about this as well and have found that since the 1150v is a modem only, no router, only port 1 is  active.  Not sure if going the Comcast business route or paying for a second IP or static IP pool will get you a second port or if Comcast would know how to enable the second port.
    • FURRYe38's avatar
      All that would be needed is to give them the MAC address of the modem and reboot the modem once they give out a 2nd IP address. The modem should see a WAN IP address on the 2nd port after the reboot. You'll need either a wired PC or another router connected to the 2nd port to check the service.
