SWDelmar's avatar
SWDelmar
Nighthawk Wifi-Router(s) - C7000V & C7100V
Can I initially please ask the differences when comparing Nighthawk Wifi-Routers of - C7000V & C7100V - if clearly possible?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    The C7000 is a cable modem/router where the C7100v is a cable modem/router with home phone hookup on it. So if you get your home phone line provided by your cable provider than you would want the C71000v.
    DarrenM
    • SWDelmar's avatar
      SWDelmar
      Hello Darren,
      Thank you VERY MUCH for presenting that to me.
      I recently had saw a higher identical Netgear Wifi/Router while also including the telphone line hookup, but not including this almost identical Product#.
      Thank you again,
          Shawn Delmar
