Bighac
Sep 02, 2017Aspirant
no voltage on POE port
Hello I'm looking for some help and advice on working out how to use my Prosafe GS10TP I purchased it to run 3 unfi Wi-Fi discs they require PoE. I cannot get the system to power the devices. I...
antinode
Sep 02, 2017Guru
> [...] my Prosafe GS10TP [...]
GS110TP? Not really a "Home Networking > Cable Modems & Routers"
topic, is it?
> [...] unfi Wi-Fi discs [...]
UniFi? Model? Power requirements? And then, what can the
GS110TP(?) provide?
- BighacSep 03, 2017Aspirant
You tell me what should it come under?
That was the only categories on the drop-down list- antinodeSep 03, 2017Guru
Are we talking about a GS10TP or a GS110TP?
Which "the drop-down list" was that?
Knowing nothing, other than that it's not a router, I put "GS110TP"
into the first "Search the Community..." box I found (at:
https://community.netgear.com/t5/NETGEAR-Forum/ct-p/en-netgear), and was
led to places like:
https://community.netgear.com/t5/Managed-Switches/bd-p/business-managed-switches
How was this determined? Did you measure the voltage?
> I cannot get the system to power the devices. [...]
"I cannot" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it.
From my brief reading, I gather that PoE is subject to control by the
device administrator. The "Smart Switch Software Administration Manual"
has a section on "PoE Configuration", for example.
Start at http://netgear.com/support/ , put in your model number,
select Documentation, download the manual(s) of interest, and peruse?
> GS110TP(?) provide?
Still wondering.- BighacSep 05, 2017Aspirant
Thank you for your patience and understanding.
What I am trying to do is add, a wireless network to my office, workshop and stores. I purchased unifi long-range Wi-Fi discs (picture enclosed) as they require PoE, I was recommended the netgear prosafe GS510TP (picture enclosed). I have a cable from my modem into port one. What feeds Internet to the other ports, but I am unable to get the PoE to work for the devices.
I hope that's a bit more clear . Thanks again for your help
