Bighac
Sep 02, 2017Aspirant
no voltage on POE port
Hello I'm looking for some help and advice on working out how to use my Prosafe GS10TP I purchased it to run 3 unfi Wi-Fi discs they require PoE. I cannot get the system to power the devices. I...
Bighac
Sep 03, 2017Aspirant
You tell me what should it come under?
That was the only categories on the drop-down list
antinode
Sep 03, 2017Guru
Are we talking about a GS10TP or a GS110TP?
Which "the drop-down list" was that?
Knowing nothing, other than that it's not a router, I put "GS110TP"
into the first "Search the Community..." box I found (at:
https://community.netgear.com/t5/NETGEAR-Forum/ct-p/en-netgear), and was
led to places like:
https://community.netgear.com/t5/Managed-Switches/bd-p/business-managed-switches
How was this determined? Did you measure the voltage?
> I cannot get the system to power the devices. [...]
"I cannot" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it.
From my brief reading, I gather that PoE is subject to control by the
device administrator. The "Smart Switch Software Administration Manual"
has a section on "PoE Configuration", for example.
Start at http://netgear.com/support/ , put in your model number,
select Documentation, download the manual(s) of interest, and peruse?
> > [...] unfi Wi-Fi discs [...]
> UniFi? Model? Power requirements? And then, what can the
> GS110TP(?) provide?
Still wondering.
- BighacSep 05, 2017Aspirant
Thank you for your patience and understanding.
What I am trying to do is add, a wireless network to my office, workshop and stores. I purchased unifi long-range Wi-Fi discs (picture enclosed) as they require PoE, I was recommended the netgear prosafe GS510TP (picture enclosed). I have a cable from my modem into port one. What feeds Internet to the other ports, but I am unable to get the PoE to work for the devices.
I hope that's a bit more clear . Thanks again for your help- antinodeSep 05, 2017Guru
> [...] Wi-Fi discs (picture enclosed) [...]
It would be more efficient to provide a simple model number than a
picture of anything.
> [...] netgear prosafe GS510TP (picture enclosed).
Picure not required, only some accurate model information. What
happened to the GS10TP or GS110TP?
What "my modem" is might be interesting. "port one" of what? The
(uncertain-model) switch?
> > GS110TP(?) provide?
> Still wondering.
It shouldn't be this difficult to get an accurate hardware inventory.- BighacSep 05, 2017Aspirant
Don't worry about it mate, sarcasm is something I don't like or appreciate.
I have boxed the piece of **bleep** up and he's going back I remember back in the 80s this stuff was a piece of **bleep** anyway!!
I rest my case with anyone classing themselves as a expert...
Get a life get out more mate...
