mattrollo
Sep 02, 2017Aspirant
open tcp ports ac1600 for use with tivo moca
How can I open several TCP ports to use my TiVo Bolt with MoCa
- Unless you are trying to access your Tivo remotely, you should not need to open any ports. The router by default does not block any ports in the outbound direction.
- mattrolloAspirantI actually had to open 9 ports but figured out how to do it using the Netgear genie under advanced while I was on hold with customer service and everything is perfect. I have to give props to Netgear for genie.
- Congrats on getting it working.
I'm curious to know which ports you had to open? According to Tivo's own support page, you do not need to open any inbound ports:
https://support.tivo.com/articles/Troubleshooting/Which-Network-Ports-and-IP-Addresses-Need-to-be-Open-When-Using-my-TiVo-DVR
