DESIi1's avatar
DESIi1
Star
Dec 10, 2016
Orbi Router and WiFi Channels
As far as assigning WiFi channels I only see that you can set the router, with 2.5GH default set to Auto and 5GH Set to 48.  There is no way to set the Satellites.  My WiFi analysis programs show that all 3 2.4GH are set to channel 5 stepping on each other.  The 5GH are all on 48.
This make no sense, is there a solution?
Firmware is 1.4.0.16
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Desli1
    You can not control the channel of the satellite separate of the base it will follow the same channel as the base.
    DarrenM
