clsimmon01
Feb 17, 2017Follower
Packet loss and reduced throughput on CG3000Dv2
I have a N450 CG3000Dv2 with 3.01.06 and having packet loss and speed degradation over time using Spectrum (formerly TimeWarner).
Upon factory reset I ran the following tests without any devices but my speedtest laptop connected:
I get the following initial up and download speeds: 60.90mbps / 5.92mbps
20 mintues later: 40.02/5.80
20 more minutes later: 8.94/5.01
Immediately reset the modem I go back to 54.76/5.80.
Clearly over time the CG3000Dv2 is not managing sessions correctly; and there doesn't appear to be any firmware updates for this modem
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello clsimmon01
I would also check with your ISP see if the levels are correct and the SNR is right.
DarrenM
