Retired_Member's avatar
Retired_Member
Dec 26, 2018
Parental Controls not working on Netgear C3700
Good day.  I just happen to be checking on my router and discovered my parental controls are no longer working.  I am hoping there is a hotfix versus me going out and purchasing another router.  Thank you in advance.  Please see my information below:
Operating system:  Windows 10 Home
Router model:  C3700
Firmware: V2.02.21
Hardware version: C279T00-01
DNS:  208.67.222.222, 208.67.220.220
Netgear Genie version:  2.4.58
Live Parental Controls:  enabled
Filtering level:  Moderate
OpenDNS account:  Created via Netgear Genie and active
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Can you give some more detail on what you have tried to do and what is not working with them?
    DarrenM
    • Retired_Member's avatar
      Retired_Member
      Good day and thank you for responding to my post.  I have reset the router.  Verified I have the latest firmware on the router.  Uninstalled and reinstalled the Netgear Genie app. I read in a thread that parental controls do not work with Wireless AP on.  I followed the steps in the thread but was unable to disable the Wireless AP per instructions given.  Could be due to the fact it was an old thread.  I deleted my OpenDNS account and recreated via Netgear Genie.  I then went into OpenDNS and added my home network to the account and verified IP addresses.  I changed parental control settings in Netgear Genie from moderate to high and waited 5 minutes.  I could still access porn sites.  I went to OpenDNS and made parental control setting changes.  I waited 5 minutes and also pushed changes via the OpenDNS agent.  Status unchanged.  I can still access porn sites.  These are the steps I have taken thus far.  Thank you.
      • antinode's avatar
        antinode
        Guru
        > [...] I read in a thread that parental controls do not work with
        > Wireless AP on. [...]
           _Which_ "a thread"?  Parental Controls may not work on a router which
        has been configured as a wireless access point (only), but that's not an
        option on a C3700.
        > [...] I followed the steps in the thread but was unable to disable the
        > Wireless AP per instructions given. [...]
           That non-description conveys no useful information.
        > [...] Could be due to the fact it was an old thread. [...]
           Could be that it didn't apply to a cable-TV modem+router like yours.
        But, with my weak psychic powers, I have no idea what this "a thread"
        actually said, or what you actually did.
