234prd
Feb 04, 2017Aspirant
Poor WiFi speed compared to Ethernet
I have a N300 C3000 cable modem+wifi router connected to comcast xfinity cable internet. When I connect any device using the ethernet cable, I get speeds of upto 225 Mbps (as against the promised 150...
Zooo05
Feb 05, 2017Aspirant
First, try unplugging your devices connected to Ethernet, and then try to connect, this can take lots of your internet speeds. Second, Ethernet devices are a lot faster because they aren't connected wirelessly. (Which I'm sure you'd understand.) Are all of your devices speeds different?
- 234prdFeb 05, 2017Aspirant
I connect devices using ethernet only while testing. All devices are always wirelessly connected. I have tested wireless connection speeds with no wired devices connected. All wireless devices get similar speeds of about 14-15 Mbps
