234prd
Feb 04, 2017Aspirant
Poor WiFi speed compared to Ethernet
I have a N300 C3000 cable modem+wifi router connected to comcast xfinity cable internet. When I connect any device using the ethernet cable, I get speeds of upto 225 Mbps (as against the promised 150...
Zooo05
Feb 05, 2017Aspirant
Try to power cycle your router and your devices, first shut off all your devices and your router, wait 3 minutes, then turn on your router, then wait another 3 minutes and then turn on your devices one at a time.
- Alabama2017Feb 10, 2017Aspirant
I just purchased this C3000.N300 cable gateway and am very pleased with it. I had another brand gateway and was getting slower speeds than promised by Comcast when using my computer wirelessly. I contacted Comcast and they advised anything connecting wirelessly would be much slower than connected via eathernet.
I connected my devices that were wireless with a eathernet, that I was able to, and my speed increased. So, as far as my computer, I went to hardwire so I could connect to the internet faster. On the other devices, I can live with a slower connection.
Hope this helps.
Alabama2017
- TheEtherFeb 10, 2017Guru
Did you try changing Wi-Fi channels? The current channel could be congested by neighboring Wi-Fi networks.
It can be really difficult to get decent speeds at 2.4 GHz. There are often too many Wi-Fi networks nearby. With N300 class Wi-Fi, you should expect to get a total throughput of around 50 Mbps to 70 Mbps. It'll be less if you are sharing the channel with other Wi-Fi networks or if there is interference from non-Wi-Fi sources.
Your best bet is to switch to 5 GHz. Unfortunately, the C3000 only operates at 2.4 GHz. There are 3 options:
- Replace the C3000 with a dual-band router/modem
- Add a dual-band router and put the C3000 into bridge mode
- Add a dual-band Access Point
- DarrenMFeb 14, 2017Sr. NETGEAR Moderator
Hello Bocamama
I X out the End of your Ip.
DarrenM
- BocamamaFeb 14, 2017Tutor
Thank you.
