234prd
Feb 04, 2017Aspirant
Poor WiFi speed compared to Ethernet
I have a N300 C3000 cable modem+wifi router connected to comcast xfinity cable internet. When I connect any device using the ethernet cable, I get speeds of upto 225 Mbps (as against the promised 150...
Bocamama
Feb 13, 2017Tutor
I have been having intermittent speed problems ever since I have purchased this unit. If I attach my computer via Ethernet, the speeds are above what my contract calls for - 50 mpbs. If I link up via wifi, the speeds fluctuate anywhere from 5 mpbs to 75 mpbs. The latter is a rarity.
My household links everything via wifi but there is never more than 3 devices at a time using it. In fact, I can't even link our MacBook Air to Ethernet; it has to link via wifi to the Internet. Also, all our other IOS devices. I have tried everything, changing channels, plugging and unplugging, calling my cable company (Comcast says it is your problem). I am getting frustrated being monkey in the middle.
Please fix this problem or at the very least, give me a credit so I can go out and buy a new device (I purchased this last year).
- TheEtherFeb 13, 2017Guru
Have you taken survey of nearby Wi-Fi networks and eliminated any sources of radio interference (e.g. baby monitors, 2.4 GHz cordless telephones, microwave ovens, Bluetooth devices, wireless speakers, etc.)?
- BocamamaFeb 13, 2017Tutor
The only thing we have is the microwave and that was niot in use. I tried changing the channel again and switched from auto to 6. It seems to have increased the speed considerably but I will continue testing for a couple of days since this has been tried before and worked only temporarily. Thank you you for your response.
Well, you should probably run a Wi-Fi analyzer and take stock of what Wi-Fi networks are active around you and the channels they are using. Then pick the least used channel. There are plenty of free Wi-Fi analyzer programs that you can download. Netgear's Genie program even has one. Pick one and try it.
As I mentioned further above, switching to 5 GHz can dramatically improve speeds. I'll recap the options:
- Replace the C3000 with a dual-band router/modem
- Add a dual-band router and put the C3000 into bridge mode
- Add a dual-band Access Point
