Cdtek101
May 26, 2016Aspirant
Port forward rules limited to 9 ports
I have a Netgear CG4500BD Modem/Router
I have 13 cams. (just got last 4)
I cant add another port forward rule (limited to 9)
so I cant add additional cams in port forwarding.
I can't make a range like 8110-8114 because it calls
for a ending Ip address ( 192.168.0. xxx ). (* see pic )
Suggestions ????
- Cdtek101Aspirant
Update :::::::::::::::::::
If I don't need to assign a port forward for each camera.
But what port do I input in camera when it says port ?
In blue iris I took out the port #,
i can see the camera inside and outside network...
but the camera ip in blue iris defaults to port 80 in configuration ?I set another cam the same way defaulting to port 80, it works also.
So - How many cameras can be on one port number ???
- Cdtek101Aspirant
Ahhhh Ha...figured it out....don't even need port forward since I have no need to log into each camera from outside my LAN....I can see all cams
outside through Blue Iris web server...
