Majji's avatar
Majji
PPPOE OPTION not displaying to setup
PPPOE OPTION not displaying to setup. Please help
  • > PPPOE OPTION not displaying to setup. Please help
       Visit http://www.netgear.com/support , put in your model number, and
    look for Documentation.  Get the User Manual.  To me, your picture looks
    like what the User Manual shows.
       The C3000 is is a cable-tv modem+router.  Why do you expect to see
    PPPoE anywhere?  Is there some actual problem which you are trying to
    solve?
    • Majji's avatar
      Majji
      I took connection from internet provider in india. Requested to provide the user and password in PPPOE settings. But it's displaying different options when I login to the netgear genie -advanced setting-setup-internet setup.
      • > I took connection from internet provider in india.
           Did that (unspecified) ISP supply the modem, or tell you which modem
        to use?
           To me, your C3000 seems to be doing what a C3000 does, which does not
        involve PPPoE.  Perhaps you should ask your ISP.  I have DSL service,
        which can involve PPPoE, but a C3000 is the wrong type modem for that.
