BagelGuy97's avatar
BagelGuy97
Follower
Feb 18, 2018
QOS not showing C3000
Hello I'm trying to enable qos on my router/modem. It is the C3000-100NAS. I believe I have the most current firmware on it. (2.02.17). It also has netgear Genie on it. From what I've found on the internet it seems I'm supposed to go to Advanced -> setup - > and then QOS setup should be under there. But it's not there. I've also tried looking underneath other tabs. Thank you for the help.
1 Reply
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    none of the NTGR modem Routers have QoS features as of today.
