eaglepi
Feb 03, 2020Guide
Question about reconnecting my network after moving. AC1750 Smart WiFi Router Model R6400
I have a question about reconnecting my network after moving. I am building a new house that is in the same city that I live now. I will be using the same ISP.
When I move the router,modem to my new house, when I plug everything in all the settings should stay the same and it should just boot up and run as if it was never moved, correct?
I know this is a dumb question but I want to make sure I know for sure prior to moving.
> [...] it should just boot up and run as if it was never moved,
> correct?Sure, if the (unspecified) "same ISP" _service_ is the same. Why not
ask the (unspecified) "same ISP", to which you'll be complaining when
something goes wrong?In a different location, the radio-interference situation might be
different, making a channel change beneficial.Your external (public?) IP address might be different, and you might
care about that (or not).As usual, many things are possible.
- eaglepiGuide
thanks for your input
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-generalGood Luck.
