txyuan
Jun 30, 2021Aspirant
Question about WMM on C7000v2
I began to experience frequent disconnections during zoom meetings. When I ping 8.8.8.8 or 192.168.0.1, it shows frequent "timeout"(3%-9%). Some of the posts suggested to disable WMM, so I did. It solved the problem. No more 'timeout" when I ping 8.8.8.8. However, after I disabled WMM, the internet speed maintained between 20-30MB/s which is lower than the average. Once I I turned on WMM, the speed went back to 70-90MB/s, but the frequent 'timeout' also occured while I pinged the router.
How can I solve this problem? Thanks.
Leave wmm on.
have you noticed if you're connected to the 2.4ghz or the 5ghz?
2.4ghz is slower and more sensitive to interference
- txyuanAspirant
The same problem occurs, no matter I connect to 2.4 or 5GHz wifi.
Thanks.
does it happen hardwired?
have you tried changing mtu size?
Ping Test to determine Optimal MTU Size on Router | Answer | NETGEAR Support
How do I change the MTU size on my NETGEAR Wireless Router/DSL Gateway? | Answer | NETGEAR Support
