stampede10343
Feb 27, 2019Aspirant
R6250 Admin panel accessible on port 80 of public ip
When I try and access my public IP I get prompted for credentials, I am able to enter my router login info and log into my router remotely.
Remote management is disabled
Port 80 is not forwarde...
- Feb 27, 2019
> When I try and access my public IP [...]
From within your LAN, or from the outside world?
https://community.netgear.com/t5/x/x/m-p/1671127
> o Port 80 is not forwarded to ANY machine
Changing that (even to a nonexistant address) might solve the
(apparent) problem. If you decide that you still care.
antinode
Feb 27, 2019Guru
- stampede10343Feb 28, 2019Aspirant
You are correct in that it is not accessible from outside my local network. Kind of weird behavior, but I'm okay with that as long as its not available outside my LAN.
Thank you!
