thedza49's avatar
thedza49
R7800 not recognizing external hard drive plugged in via USB
Hey Everyone,
Title pretty much says it all.  I have a 3.5 Western Digitial Red NAS drive that is 4TB plugged into an amazon external hard drive enclosure trying to get my router to recognize it.
Odd thing is that I was able to pull this hard drive into my mac, format the drive and copy over files no probelm.  I plug it into the second USB connection on the router and readyshare doesn't seem to recognize it.
I did this with a previous hard drive that was the same set up and it worked fine but now with this one it's not working.
Not sure if there is a way to troubleshoot this or if there is a specific disk format I need to use on my mac Disk Utility app?
Thanks,
Dza
  • FURRYe38's avatar
    What format did you use on the drive? I think NTFS and FAT32 or EXT are ones that are supported by NG. Check the manual.
    Does the external drive enclosure have it's own power supply?
    • thedza49's avatar
      thedza49
      I think I selected the first option on Disk Utility on my Mac which was the APFS.
      The enclosure has it's own power source.
      • FURRYe38's avatar
        Ya, thats not supported on NG I believe. Try NTFS or EXT
