jsomaini's avatar
jsomaini
Re: Nighthawk CAX80 login loop
I have the same issue.  When trying to authenticate to the web service (on the router), it forces a reauthentication.  Eventually, it asks for the serial number to reset the pw.  Even after doing that, it still has the same issue.  I've rebooted multiple times, verified the password is correct etc, etc...
No idea what the issue is.
  • FURRYe38's avatar
    What browser are you using? Try a different browser, MS Edge, Firefox or Opera.
    Be sure to clear out all browser caches before navigating to the modems web page.
    Has a factory reset and setup from scratch been performed since last update?
  • plemans's avatar
    have you made sure the password meets these requirements?
    10 characters with at least:
    1 special character
    1 upper case
    1 lower case
    1 number
    • jsomaini's avatar
      jsomaini
      How can you backup the config if you can't log into the web interface?  (hence the issue we are having).
      Thanks
  • FURRYe38's avatar
    Please give feedback to the questions presented.
