ezou
Sep 09, 2016Aspirant
ReadyShare DLNA Server Disconnects during music streaming
Hi,
I have connected a Seagate Backup 2T USB drive to Netgear CableModem router (C3000) to serve as media server.
On the player side, I connected a Marantz NA8005 network music player to the router wired via ethernet.
The player is able to see "readyshare DLNA: C3000" server initially, and I can browse the folders, and play music. However, after 5-10 minutes, it will stop with a message "server disconnected". At this point, I am also not able to browse the media folder from my PC. The only way to recover is to restart the router. It will then function properly for 5-10 minutes before server get disconnect again.
Any suggestions on what I need to do?
-ed
- boxcar-7GuideHello, you are most likely having the same difficulty I was having. I also wanted to stream from my Seagate 2TB Slim Hard Drive, and every time I did it stopped. This is because the drive is drawing power through the USB from your router. That interrupts the data streaming. I tested the router with different drive that had its own external power the movie played just fine from start to finish. So, I looked into externally powering my Seagate 2TB Backup Slim with 3.0 USB drive. Here is what I found: https://www.sabrent.com/product/EC-DFLT/usb-3-0-sata-external-hard-drive-lay-flat-docking-station-2-5-3-5in-hdd-ssd Or something similar. I believe this will solve our problem. I asked the question on a different community post and waiting to hear from them. I asked the question to Sabrent, they weren't sure, asked Seagate, they thought issues, I'm just now waiting to hear from Netgear support before I spend the dollars. Hope this helps and good luck. Boxcar-7....
- boxcar-7GuideEdit to correct..."asked Seagate, they thought there should be no issues" Boxcar-7
- ezouAspirant
boxcar-7,
Thanks for the reply. Based on your reply, I tried to use an older Simplify 1T drive with external power to connect with the router. Similar issue occured: the player connected with it, play 2 songs then the server error appears. the only way to overcome it is to restart the router. They everything works fine for about 2 songs before server error occurs again.
-ed
- DarrenMSr. NETGEAR Moderator
Hello ezou
Have you tried to rename the Media Server Name see if that makes a difference.
DarrenM
- ezouAspirant
Hi Darren,
Yes. I did renamed it to NAS. That didn't solve the problem. Same issue, after 2-3 songs, the play lost connection with the server. I renamed the media server name...same result.
Once I power off and on the router, it works fine for 2 songs:(.
-ed
