bergerpjr's avatar
bergerpjr
readyshare drive not usable in DOS command prompt
I have a C700 Nighthawk - AC 1900 WiFi Cable Modem Router where I setup the ReadyShare USB drive access. When I type in the UNC path "\\READYSHARE\USB_Storage" and type in the Admin password for wri...
  • bergerpjr's avatar
    Oct 20, 2016
    Status update: It is working now.?
    I've upgraded to the latest Windows 10 version (1607.14951.1000).
    I also upgraded Netgear Genie to v2.4.32.
    I "can" now use/see the Readyshare drive in a CMD shell.
    I can run all of the normal DOS commands on this mapped drive just fine.
    I had to tweak my robocopy script to remove the /COPYALL and /ZB parameters as I guess Linux/NAS doesn't support those parameters, but I can now, with the click of a desktop shortcut - synchronize/backup my local files over the network to the NAS drive.
    I am not sure if it was the change in Windows or in Genie that did the trick though.
    hope this helps others too.
