Leda
Jun 19, 2016Novice
Recommendation for - Best wireless VPN Gigabit+ Wireless Router
Am replacing my "nerve center" which is out of date and need a new router and modem that works with Time Warner. I would prefer a POE router if such an animal exist with VPN ability. Am trying to s...
TheEther
Jun 20, 2016Guru
Netgear doesn't have a model that meets all of your requirements. None have 8 LAN ports (you can always buy a 5 port switch for expansion). None have POE. You didn't specify if you need VPN server or client support (probably server but I won't assume).
You should look at TWC's list of approved modems and modem/router units.
http://www.timewarnercable.com/content/dam/residential/pdfs/support/internet/twc-compatible-modems.pdf
