jpwalsh4me
Jul 17, 2020Aspirant
remove, disable shareready on C7000
I have just installed a Netgear c7000 cable model and wifi router and want to remove, or disable, the default Readyshare feature. This is unneccessary for my environment
Great to hear. Glad that worked. Thanks for sharing. Mark your thread as solves so others will know.
Enjoy, :smileywink:
There should be a menu option to uncheck and disable that feature on the modems web page.
Review the user manual to see about this feature.
> [...] C7000
C7000[v1] or C7000v2? Look for "Model" on the product label.
> [...] want to remove, or disable, the default Readyshare feature.
> [...]What leads you to believe that the ReadySHARE feature is enabled
now? Did you connect a USB storage device (or printer) to the
C7000[vX]?Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for a
topic like 'Share USB Devices Attached to the Modem Router". Read more.
Panic less.- jpwalsh4meAspirant
Netgear was defaulting to the "Basic" option for ReadyShare. So, I downloaded Netgear's USB Control Center and unchecked "Run Basic when windows is active". That did the job.
Enjoy, :smileywink:
