SugarlessGrub5
Jul 30, 2020Aspirant
Replacement power adapter for CM1000v2
Where could I purchase a replacement power adapter for the CM1000v2 cable modem? Any help would be appreciated.
Try places let Amazon. Look for same spec voltage and amps as listed on the sticker of the power adapter.
- SugarlessGrub5AspirantDoes it have to be a Netgear power adapter? Will the modem be compatible with any power adapter as long as the volts and amps are correct?
Correct, as along as the volts, amps and size of plug are the same, the modem will work fine with non NG branded power adapters.
