TheTooleMan's avatar
TheTooleMan
Roku 2 Won't Retrieve Some MP4 Files From ReadyShare Network Drive
My new Roku 2's Media Player will not retrieve and play some MP4 files from the WD Elements hard drive connected as a ReadyShare drive to my Netgear EX6300. Many MP4 and MKV files load and play just fine from the ReadyShare drive, but certain ones hang at about 10% on the "retrieving" screen and never load. I put an MP4 file that would not retrieve via the router on a USB thumb drive and plugged it directly into the Roku, and it retrieved and played perfectly. What could be going on?
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello TheTooleMan
      Is that file bigger than the others? also try to move the file to a different folder on the drive could just be a strange issue.
      DarrenM
      • TheTooleMan's avatar
        TheTooleMan
        Other larger files stream OK. I don't see how putting it into another folder would do any good.
