ldyork's avatar
ldyork
Tutor
Apr 07, 2018
Router Compatibility with Crestview Cable
Can anyone tell me if this cable/Wifi/voice router (C7100V-1AZNAS) works with Crestview Cable/voice?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello idyork
    You will have to check with the ISP but that only supports comcast at the moment.
    DarrenM
    • ldyork's avatar
      ldyork
      Tutor
      Tried that three weeks ago and got no response.  Guess I'll have to get more aggressive.
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    dont buy. it wont work.
    this product is heavily customize to work with XFINITY/Comcast *ONLY*.
    I suggest not to waste your time and money. on top of that, I suggest not to buy any other devices from retail unless your ISP says it is supported.
    your best bet is to seperate voice and data using 2 different modems.
    • ldyork's avatar
      ldyork
      Tutor
      Thanks for the response.  My question exactly related to xfinity although Crestview did answer my call and said all gateways except Motorola and one I forget would work including Netgear.  The C7000B sounds like a great solution but not available for mere mortals only ISP's.
      • ldyork's avatar
        ldyork
        Tutor
        Just remembered.  The other one not recommended was Zoom.
