bscott1414's avatar
bscott1414
Router randomly blocking websites
Actual model is C7100V.
I've seen this issue with others in the past, but my newer router/modem admin portal does not have the MAC cloning option shown to have fixed earlier models.  I am able to get to most websites.  There are a few, (monoprice.com, expresstoll.com and a banking site) that I am unable to connect to.  The message I receive is: (for example)
The requested URL was rejected. Please consult with your administrator.
Your support ID is: 536827395421069
Each attempt generates a new support ID.  I've attempted resetting the router multiple times and have confirmed that my isp (xFinity) is not blocking anything.  If I turn wifi off on my phone, I'm able to access all of these sites.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello bscott1414
    Have you tried changing your DNS to see if that is the issue?
    DarrenM
    • bscott1414's avatar
      bscott1414
      Yes.  I've tried using Google DNS as well as some provided by xFinity to test the same.  Interestingly, when I go to websites that use location services, I keep getting tagged as being in San Fransisco.  Comcast/xFinity are saying that the time zone is auto configured by them, but that this router is hard coded to PST.  I can't find any way to change the time zone to my correct time zone.
      Why would Netgear hardcode a time zone?  That would be such a monumental design flaw as time can and does affect communications if a server Host sees the time as out of synch.  Is this a bad router?
      • DarrenM's avatar
        DarrenM
        Hello bscott1414
        The modem gets its time data from the CMTS of the ISP and they do not typically follow daylight savings is the time a hour off? does the same error show up no matter what web browser you use or what device you use in the home?
        DarrenM
