rebeccar
Jul 07, 2020Aspirant
Seeking opinion: Time to replace C3700?
 Is it time to buy new?  In late March, my Comcast connection began to frequently fail. Comcast tech support blamed my C3700 Cable Modem Router purchased in 2015. I suspected that Comcast wasn't able ...
Jul 07, 2020Guru - Experienced User
You might try the C3700 in modem mode only instead of router/gateway mode. Then find you a external wifi router to connect to the modem. NG has exdernal router, R, RAX or Orbi systems available.
