edpnw
Mar 30, 2024Aspirant
Simulated Sine Wave UPS?
Hello -- In buying a new UPS for my C7800 WiFi Cable Modem Router, I'm wondering if I can get by with a cheaper simulated sine wave UPS or if I should buy a full sine wave UPS. Or, for that matter, even a super-cheap step wave unit. I believe it depends on the kind of power supply used by the router but I don't have the knowledge or background to understand these things. Thank you!
I would think any good quality UPS that provides power specs for the modem should work. APS makes good quality UPS.
