ddflink's avatar
ddflink
Slow Wifi - C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router
I have a C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router with Comcast service up to 100 mbps. the modem is in the basement connected to a luxul xp-1500 extender (into the basement ceiling) and two other tp extenders in the house (RE450 main floor & RE305 second floor). Yet my wifi signal is between 5-20 mbps. Would anyone know what settings I would need to modify to get optimum speeds?
Thank you!
Dave
  • FURRYe38's avatar
    What speeds to you get with just the wifi on the C series modem only? Turn off all other extenders.
    • ddflink's avatar
      ddflink
      Currently i'm getting 50 mbps from 2.4 and 100 from 5g and similar from the extenders but it's very spoty
      • FURRYe38's avatar
        Might go with NG extenders to see if those work better. EX7000 would be a good match...
        ALso distance with extenders is important. 30 feet to start in between the modem and extenders is a good starting point. Depending upon building materials. Concrete and steel will impact wifi travel.
