goobledegook
Jan 09, 2025Aspirant
Switched from CM3000 to CAX80 and it destroyed upload/download speeds
So I recently moved to Benicia, CA and signed up for the 2Gbps download 300Mbps upload package Xfinity offers. At first I got the CM3000 just missing the fact that it only supported 1Gbps but ran a speed test and got what I was expecting (941Mbps down and 358Mbps up). I decided to get the CAX80 since it has the 2.5Gbps port and I wanted the Wifi. So I replaced the the CM3000 with the CAX80, registered it with Xfinity, went through the set up process using the Nighthawk app and now I'm getting worse speeds (700Mbps down, and 5.88Mbps up). I haven't changed my set up in any way other than doing this. What's going on?
So to reiterate (ran these tests multiple times on both modems):
CM3000: 941Mbps down and 358Mbps up
CAX80: 700Mbps down (1.34x slower) and 5.88Mbps up (60x slower!)
CAX80 Firmware Version: V5.1.1.8
CAX80 Cable Firmware Version V1.02.08
OS: Windows 11
Any suggestions/ideas? Been searching but any related posts are old.
Downstream Status: Poor
Downstream Power Level: Poor
Downstream power is poor (10.3dBmV). The recommended level is between -10dBmV to 10dBmV.
Downstream SNR: Good
Upstream Status: Good
Upstream Power Level: Good
Current time: Thu Jan 09 00:24:35 2025
Startup Procedure
Acquire Downstream Channel: 639 MHz Locked
Connectivity State: OK Operational
Boot State: OK Operational
Security: Enabled BPI+
Downstream Bonded Channels
Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
1 Locked 256 QAM 44 639000000 Hz 10.3 dBmV 44.2 dB 0 0
2 Locked 256 QAM 13 453000000 Hz 7.5 dBmV 43.7 dB 0 0
3 Locked 256 QAM 14 459000000 Hz 7.6 dBmV 43.7 dB 0 0
4 Locked 256 QAM 15 465000000 Hz 7.7 dBmV 43.7 dB 0 0
5 Locked 256 QAM 16 471000000 Hz 7.9 dBmV 43.9 dB 0 0
6 Locked 256 QAM 17 477000000 Hz 8 dBmV 43.9 dB 0 0
7 Locked 256 QAM 18 483000000 Hz 8 dBmV 43.9 dB 0 0
8 Locked 256 QAM 19 489000000 Hz 8.2 dBmV 44 dB 0 0
9 Locked 256 QAM 20 495000000 Hz 8.2 dBmV 44.1 dB 0 0
10 Locked 256 QAM 21 501000000 Hz 8.3 dBmV 44.1 dB 0 0
11 Locked 256 QAM 22 507000000 Hz 8.6 dBmV 44.2 dB 0 0
12 Locked 256 QAM 23 513000000 Hz 8.5 dBmV 44.2 dB 0 0
13 Locked 256 QAM 24 519000000 Hz 8.7 dBmV 44.3 dB 0 0
14 Locked 256 QAM 25 525000000 Hz 8.7 dBmV 44.3 dB 0 0
15 Locked 256 QAM 26 531000000 Hz 8.8 dBmV 44.3 dB 0 0
16 Locked 256 QAM 27 537000000 Hz 8.8 dBmV 44.3 dB 0 0
17 Locked 256 QAM 28 543000000 Hz 8.7 dBmV 44.2 dB 0 0
18 Locked 256 QAM 29 549000000 Hz 8.7 dBmV 44.2 dB 0 0
19 Locked 256 QAM 30 555000000 Hz 8.9 dBmV 44.3 dB 0 0
20 Locked 256 QAM 31 561000000 Hz 8.9 dBmV 44.3 dB 0 0
21 Locked 256 QAM 32 567000000 Hz 9 dBmV 44.3 dB 0 0
22 Locked 256 QAM 33 573000000 Hz 9.1 dBmV 44.4 dB 0 0
23 Locked 256 QAM 34 579000000 Hz 9.2 dBmV 44.4 dB 0 0
24 Locked 256 QAM 35 585000000 Hz 9.3 dBmV 44.4 dB 0 0
25 Locked 256 QAM 36 591000000 Hz 9.3 dBmV 44.4 dB 0 0
26 Locked 256 QAM 37 597000000 Hz 9.4 dBmV 44.4 dB 0 0
27 Locked 256 QAM 38 603000000 Hz 9.6 dBmV 44.5 dB 0 0
28 Locked 256 QAM 39 609000000 Hz 9.5 dBmV 44.3 dB 0 0
29 Locked 256 QAM 40 615000000 Hz 9.6 dBmV 44.3 dB 0 0
30 Locked 256 QAM 41 621000000 Hz 9.9 dBmV 44.4 dB 0 0
31 Locked 256 QAM 42 627000000 Hz 9.9 dBmV 44.4 dB 0 0
32 Locked 256 QAM 43 633000000 Hz 10.2 dBmV 44.5 dB 0 0
Upstream Bonded Channels
Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
1 Locked ATDMA 19 5120 Ksym/sec 29200000 Hz 42.0 dBmV
2 Locked ATDMA 18 5120 Ksym/sec 22800000 Hz 42.0 dBmV
3 Locked ATDMA 17 5120 Ksym/sec 16400000 Hz 41.5 dBmV
4 Locked ATDMA 20 5120 Ksym/sec 35600000 Hz 42.3 dBmV
5 Not Locked Unknown 0 0 0 0.0
6 Not Locked Unknown 0 0 0 0.0
7 Not Locked Unknown 0 0 0 0.0
8 Not Locked Unknown 0 0 0 0.0
Downstream OFDM Channels
Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
1 Locked 0 ,1 ,2 ,3 193 722000000 Hz 12.58 dBmV 45.1 dB 388 ~ 3707 397620190 110024534 0
2 Locked 0 ,1 ,2 ,3 194 957000000 Hz 16.18 dBmV 45.3 dB 148 ~ 3947 405019767 4324629 0
Upstream OFDMA Channels
1 Not Locked 0 0 0 Hz 0 dBmV
2 Not Locked 0 0 0 Hz 0 dBmV
Event Log
Time Priority Description
Wed Jan 8 23:50:08 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 23:43:25 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 21:42:38 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 21:38:17 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 20:33:41 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 20:29:14 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 20:28:53 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 20:26:47 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 19:37:12 2025 Critical UCD invalid or channel unusable;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 19:37:12 2025 Notice DS profile assignment change. DS Chan ID: 33; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 19:37:10 2025 Notice DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 19:37:09 2025 Notice TLV-11 - unrecognized OID;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:29 1970 Notice Honoring MDD; IP provisioning mode = IPv6
Thu Jan 1 00:00:22 1970 Critical UCD invalid or channel unusable;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:21 1970 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 19:28:40 2025 Critical UCD invalid or channel unusable;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:30 1970 Critical UCD invalid or channel unusable;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:29 1970 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 18:04:30 2025 Critical UCD invalid or channel unusable;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:26 1970 Critical UCD invalid or channel unusable;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:25 1970 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 17:44:16 2025 Critical UCD invalid or channel unusable;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:45 1970 Critical UCD invalid or channel unusable;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:43 1970 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 17:42:03 2025 Critical Resetting the cable modem due to docsDevResetNow
Wed Jan 8 17:35:05 2025 Critical UCD invalid or channel unusable;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:46 1970 Critical UCD invalid or channel unusable;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 17:29:18 2025 Critical UCD invalid or channel unusable;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jan 8 17:26:23 2025 Critical UCD invalid or channel unusable;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:03:15 1970 Critical No Ranging Response received - T3 time-out;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:03:12 1970 Critical UCD invalid or channel unusable;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:90:f0:1c:02:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:02:53 1970 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:46 1970 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=54:07:7d:c3:7a:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
- goobledegookAspirant
Just wanted to post this here as well as the CAX80 is recommended for 2Gbps download (although curiously doesn't not list upload speed).
Power levels are too high:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Find you a -6Db coax attenuator.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/- plemansGuru - Experienced User
You sure you have the CM3000? It supports multigig and the increased upload from xfinity. The cax80 doesn't have the next gen upload speeds.
Since the power is out of spec and your seeing Criticals when you had the CAX80 online:
This means the CAX80 is not getting good ISP signal on the line. Power is TOO HIGH and any criticals, errors or warnings in the event logs means there is signal issues on the ISP coax line. Too high power will eventually burn out the modem. So the CAX80 will not be working as designed. Also since you have the CM modem online now, the CM modem maybe seeing same issues.
All these would cause problem and lead to what your seeing.Hope your CM3000 won't see problems.
Good Luck.
