jleecole
Aug 12, 2023Aspirant
sync time synchoniztaion failure, streaming buffering
I started having issues with select streaming services buffering about a month ago. I installed cm1000v2 modem with eero mesh system and the problem sill persists. The log shows sync time synchonizati...
- Aug 12, 2023
Eeeks, Lots of criticals and such. Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
Aug 12, 2023Guru - Experienced User
Please post the event log page as well.
jleecole
- FURRYe38Aug 12, 2023Guru - Experienced User
https://highspeed.tips/docsis-events/- jleecoleAug 12, 2023AspirantGreat thanks! Hopefully it will get fixed..
- jleecoleAug 13, 2023AspirantWould these errors cause certain streaming services to not work? Ie. Sling and YouTube TV work, Hulu is sketchy and peacock and oxygen through Roku do not. Does each streaming service have their own way of connection? Also some websites on my phone will hang until I turn wifi off and on again..
- FURRYe38Aug 14, 2023Guru - Experienced User
Yes.
