LokiMofo's avatar
LokiMofo
Traffic Meter Units Displayed & By Device?
TWC is saying that I have used 693+ GB this month (9/1 to 9/20) compaired to 308 for the previous month. How the heck do I convert the data reported in the traffic meter and is there a report with mo...
  • Anonymous's avatar
    Anonymous
    Sep 21, 2016
    Moving forward .......your usage function is not setup so you should set it up.
    The numbers shown on the screenshot you posted, to me seem to be WRONG! Maybe because usage was not setup I don't know.
    reset the counter, enter the settings and watch it for a few days OR better yet push reset until power LED flashes use defaults to login reset the counter again.
    if I used 250GB MY router would display 256000MB
    so it would seem something on your end most likely never setting up the usage is why the numbers look ridiculously large
    According to today you already used 34GB
