Kakashi2000
Jun 04, 2016Star
try to reduce false and posive attack
netgear corp try to reduce false and positive attack some attack cold drop the network becase the modem or raouter think they are real but are false and pisitive attack so i recoment you ne...
TheEther
Jun 04, 2016Guru
What you are asking for is not going to be cheap. A low-end Barracuda Networks Firewall, for example, costs almost $700 (USD).
Kakashi2000
Jun 04, 2016Star
i know bro it cost
but netgear cold do something better they can make security home more secure
to help home user state more secure
iknow corporative firewall are most avance and more secure that is was cost more
i am just trying to help lol
- TheEtherJun 04, 2016Guru
We have a saying, "Fast. Good. Cheap. Pick two." You are asking for all three.
- frankeezipperJun 05, 2016Aspirant
What I would like to see is a flash drive that can be used to set up the router/ modem before it is put online. The netgear genie comes wit the default of the IPV6 firewall disabled and the http and https already checked. When a hacker jas a snoop or sniffer out there waiting it onlu takes mlleseconds for them to infiltrate your network. Once there, they are in and there is no getting rid of them.So Netgear, dont check the default and even thos a little more cost for a thumb drive to initialize the router before it is put on line would be worth the money
