TylerDNA
Aug 03, 2017Tutor
Trying to bypass firewall on C6300 for VPN server
Hi all, I am trying to turn a raspberry pi into a vpn server for my home. I want to do this so I can remotely monitor my home computers while I am away from the house. I have assigned my pi a sta...
- Aug 04, 2017
Actually, the pi community's ability to help stops at the internal firewall settings of the C6300.
UPDATE: By enabling my VPN's IP address to be the Default DMZ Server I was able to connect to my home network from an outside network. That was the solution.
michaelkenward
Aug 04, 2017Guru - Experienced User
Wouldn't the Pi community be a better bet for advice on this?
You may be limited because you are using a cable modem/router. There is a community of unofficial router hackers out there, but they don't handle all hardware, preferring to work on routers when they produce customised firmware for Netgear kit.
- TylerDNAAug 04, 2017Tutor
- michaelkenwardAug 04, 2017Guru - Experienced User
OK. I've just written >3000 words about the Pi and the people who invented it praised the skills and knowledge of the user world.
I thought later that the VPN approach might not be needed so much as Allow Remote Access. But that may not give you everything you want.
