MizzV55
Jun 28, 2016Aspirant
Trying to find an answer regarding AC1750 model C6300 PLEASE HELP!!!!
I have an AC1750 C6300 router modem, I have been trying to find area coverage for the WiFi from this equipment, because I am moving into a 3 story house. There are no of us who all have some sort of ...
MizzV55
Any idea on what plugin extenders may work well with what I have if they're needed? House is new a totally cable/Ethernet ready.
New house in a neighborhood so I'm sure there will be a level of other systems nearby.
TheEther
Jun 28, 2016Guru
Awesome, with Ethernet you are in a great position to extend Wi-Fi without the usual speed penalty that comes with a wireless range extender.
How fast is your Internet service?
If your budget allows get one or two ACxxx extenders, or you do go lower end if your Internet speed is slower. Connect the extenders to Ethernet and enable Access Point mode. You can download the manuals for Netgear's range extenders by clicking on Get Support for each model. Then read up on how to enable Access Point mode.
