levelred
Nov 06, 2015Initiate
TWC + C3700
Why not publically relases the fix? I need this fixed! Instead searching and sending PM the fix should be listed publically! BTW can I have the fix. This is annoying!
- remiliaTutorTWC just came & they're blaming the slow speed to the C3700 router for slow speed. Is there a way to fix the slow internet connection? Please help, thank you.
- remiliaTutorCan you help me out, thank you in advance.
- kosballasAspirant
Hi,
I have the same problem. TWC updated my firmware to V2.02.06.Now i have almost no internet at all. They told me i need v1.01.11 for netgear c3700 to work properly but still waiting for the downgrade. Can someone help? any way i can get v1.01.11 by myself?
Thank You
