Kakashi2000
Sep 27, 2016Star
Ultimate most powerful ideas for security
hi netgear here new ideas for ultimate security to prevent thos fuking hakers
for modem and raouters
make here
the ultimate anti exploit and exploit mitigation for all
new anti exploit and Exploit Mitigations
new process protection software
new usb protection
Network Lockdown :Helps to stop attacks that connect back to command-and-control
Advanced Threat Reporting and logs
new network anti explot and mitigation = prevent ip clone ,prevent mac pc or modem clone ,prevent dns clone ,prevent device to be clone ,prevent modem config file be corrupted ,prevent dos and portscan or any other security crash ,tricked or hack or modifie by a haker ,prevent full brute force to crash the modem by any attack to gain acess to the connection or ect,prevent walan or wirless been attack by brute force or bypass
make new security level more higther that https for modem and router login
new memory anti exploit or brute force
software anti exploit
cpu protection and anti exploit
all sharing turn off and put a encription so nope one can turn it on
make new anti exploit wirless to prevent haking and information stealing and eardrops
make dns protection
scrip protection and scrips manipulation and bypass by brute force or comand
new bloking device and security
Anti-Ransomware
Privacy and Espionage Protection
Hardware-assisted Control-Flow Integrity (CFI) =Stops advanced ROP attacks
Keystroke Encryption=Protects credentials against keyloggers in the browser
new next gen firewall anti exploit ,anti bypass,anti corrup,unrideble firewall by hakkers or cia ,nsa,spying, unable to read firewall or learn firewall by any attack how wahnt to learn the code or how is works
new 4 or 6 smart layers firewall
new firewall level security
make turbo firewall for gaming in all options and extreme nat aceleration
: firewall off
:firewall normal
:firewall higth security
:new firewall ultimate anti haking mode =set all port in and device and ect in to ultimate stelth mode super hidden mode =that mean you will navegate in invisible mode all port hidden and ect protecting you to be trace by any command network
this mean all your mac ip ect will be invisible to them
;new optional mode set full firewall block network from conecting to this pc that mean you can navegate ect but some one from the outsite are unable to enter to your pc
new block or remove data collection navegation to be more private from browser ect
new anti exploit cookie and browsers
new prevent malware or virus ect infect the modem or router using any means and send bad traffics
prevent upnp be track and bypass or brute force
prevent firewall slowdon by any attack or extreme junks or ect
fix log delete it selft when modem or router reset put a password or lock to prevent been delete
prevent nat been crash or attack ,slowdown
prevent voip bypass or spy
change the full name of the modem or raouter and prevent hakers know what name of the device you are using when they try to login
make to change mac adress or make ramdow mac adress to prevent your device or modem been hack and be invisible
make to detect all hiden device and ports ect in case some is using a hiden program ect
make a new software backup protection and unhakeable
make a new remote protection
make a new media server protection
make a new limnit computer you whant to connect to the modem or raouter if you set 1 computer only one computer can connect prevent this to be bypass or faked using programs
you need to make a new modem software ,faster stronger ,super extreme stable and secure
new secure boot state for the modem or raouter cold be hack or modfie or bypass or ect
fix false and positive attacks
make new firewall profecional monitor and network and wirless monitor
prevent disconnection for any attack on any games
make lan new protection mode and security
make remove uknow trafics and ect
prevent firewall leak by anything and ect
just helping make the best of the best with the ultimate software and security ,iknow you can do this netgear corp
make anti exploit programs shild and protection
just helping
- VE6CGXMaster
Lots of ideas but the irony is there is no such thing as 100% guranteed security, no matter what. Man can break anything man made.
Been there, done that.
i know bro just trying to help
