Chance45's avatar
Chance45
Upgrade to CM1200 from cm1000
Just wondering if anyone has upgraded their cm1000 to cm1200 modem. I recently made the switch but it's looking like cm1000 is more consistent and faster than the cm1200.
  • plemans's avatar
    If you're using the cm1200 with link aggregation enabled, disable it.
    • Chance45's avatar
      Chance45
      Its actually currently on disable. Should I try it with Enable (LACP-IEEE 802.3ad) (Port 1 & 2) on?
      • plemans's avatar
        no. its fine.
        The cm1200 and the cm1000 use basically the same chip. So there really shouldn't be a difference in performance unless you're using the wan aggregation.
        Do you have a screen snip of the cable connections page from it?
