DCV129
Nov 11, 2018Aspirant
Upgrade to new router from C-3000 modem/router
I am considering upgrading to a newer Netgear router from my current C-3000 modem/router on Comcast service, which works fine, but has a great deal of buffering on wi-fi online ROKU (not cable) TV s...
- Nov 16, 2018
Since you are using a C3000 you will need to buy a combo unit which has a modem built in so any netgear product with a C# would be what you want.
https://www.netgear.com/home/products/networking/cable-modems-routers/
DarrenM
DarrenM
Nov 16, 2018Sr. NETGEAR Moderator
DarrenM
- DCV129Nov 16, 2018Aspirant
Thanks, DarrenM! After posting my issue, I read the online documentation for my existing modem/router and, it appears, I can disable the router function, keeping the modem function and connect a new Netgear router to the existing modem/router (with the router function disabled). Your suggestion seems a better plan - simply buy a new Netgear combo unit with a C#. Thanks for clarifying that for me (and, hopefully, for any other Netgear user who is looking to upgrade for better performance.)
