hambone69
Jan 30, 2017Aspirant
Upgraded from Time Warner to Spectrum, speed issues C7000 AC1900
I searched on this community and couldn't find an answer. Recently my time warner cable switched to Spectrum. I had 15 mbps with time warner and spectrum upgraded me to 60 mbps. I did a speed test...
netwrks
Jan 30, 2017Master
The modem portion of the C7000 may not be sanctioned by Spectrum. Should have them come by with a new device to see if it changes anything. Worst case, you could use the C7000 configured as an Access Point..
hambone69
Thanks for the reply. They are sending me a modem/router, I guess I'll hook it up and see if it's any better
- DarrenMFeb 01, 2017Sr. NETGEAR Moderator
Hello Hambone69
Have you tried to facotry reset the modem it may on not got the new config for the faster speed since they changed that. You may also want to have them check to make sure they coded your modem correctly in there system to get that new speed.
DarrenM
