DongKim
Jun 02, 2016Aspirant
upstream LED light for C6300
I bought this modem router about 1 month and it worked fine
then i realized that upstream light on the front pannel is "RED" what i remember was green
so i looked it up for user manual for it and it said green light is normal state and I don't know where is this red light came from
is there anyone having same issue with me?
or is it fine with red light on?
fyi. the internet works fine.
- DarrenMSr. NETGEAR Moderator
Hello Dongkim
You will want to contact your ISP have them check on the modem as it means only 1 upstream channel is locked. i would just have them run some tests on your connection make sure it is fine.
DarrenM
- DongKimAspirant
Hi thank you for your reply
I called to my ISP which is Comcast
they were trying to lock onther channel or so
but they couldn't be able to connet to the router
so that they suggested me to contact Netgear again
internet still works but the LED light is still "RED"
DongKim
I would contact our support at this point.
http://www.netgear.com/support/contact.aspx?cid=gwmng
DarrenM
- ThehawkGuideSame here. My upstream light is yellow
