shumm
Sep 15, 2016Aspirant
Use my N600 WiFi Cable Modem Router as an extender?
I'm moving into a new place and the main house has a wifi router already there set up. I'd like to use my N600 as an access point in the cottage behind the house. Can I wirelessly connect my N600 to the router inside the house and use it to get wifi secure coverage in the cottage?
- Anonymous
N600 is not a router model, it's a marketing tool. The Model # is on a label on the router. Once you locate it you can find a manual via the download link at top of this page.
No to your question.
- shummAspirant
Hi. I don't have the router with me at the moment, but Amazon tells me it is a C3700 model.
What does "no to your question." mean? I can't use it as an extender?
- Anonymous
Yes,
Use the dowload tab above and locate the manual for any netgear product you're considering. If you need a extender then purchase one.
Why would you even consider a cable modem router to be used as a extender?
