shumm's avatar
shumm
Use my N600 WiFi Cable Modem Router as an extender?
I'm moving into a new place and the main house has a wifi router already there set up. I'd like to use my N600 as an access point in the cottage behind the house. Can I wirelessly connect my N600 to the router inside the house and use it to get wifi secure coverage in the cottage?
  • Retired_Member's avatar
    Retired_Member
    N600 is not a router model, it's a marketing tool. The Model # is on a label on the router. Once you locate it you can find a manual via the download link at top of this page.
    No to your question.
    • shumm's avatar
      shumm
      Hi. I don't have the router with me at the moment, but Amazon tells me it is a C3700 model.
      What does "no to your question." mean? I can't use it as an extender?
        Retired_Member
        Yes,
        Use the dowload tab above and locate the manual for any netgear product you're considering. If you need a extender then purchase one.
        Why would you even consider a cable modem router to be used as a extender?
