jazzgal
Apr 16, 2024Aspirant
using 2.4GHz band
I am attempting to connect a nanny cam to my network; my router is a C7100V with dual bands. The camera requires a 2.4 GHz frequency, but I can't seem to connect to my network. How can I confirm that I am using the 2.4 GHz frequency rather than the 5 GHz frequency?
I am not tech fluent so please keep responses simple. 🙂
I would log into the modems web page and check to see if Smart Connect is enabled or disabled. Disable Smart Connect if seen there then use the 2.4Ghz SSID name to connect your devices to the modem. Log in at 192.168.1.1 in a web browser on any PC or laptop.
- jazzgalAspirant
Thank you for the very helpful reply, but I don't see Smart Connect anywhere.
Ok. Should have separate WiFi SSID names for each frequency then. Just use the one for the 2.4Ghz wifi for your devices. You can give a new name to each frequency if you like and it's recommended. Can be most anything. Make it intuitive and fun.
