Pravin82's avatar
Pravin82
Follower
Sep 12, 2015
Very low speed on wifi Netgear C3000
I am using 105 mbps on Xfinity internet. On ethernet cable the speed comes close to 100 mbs, but on wifi its hardly 10 mbps. Comcast is saying this is the issue with my modem. Any suggestion on this please?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Pravin82
    You don't happen to have a old 802.11B device connecting to the wireless network because if you do it will drag the whole wifi network down to 11Mbps or slower. If that's not the case I would suggest trying to change your wireless channel to see if that helps some other wifi signals or home appliances could be interfering with your wifi. Hope to hear your feedback.
    DarrenM
    • RJ007's avatar
      RJ007
      Hello,
      I bhought the modem/router- c3700 few days back and am facing the same issue as stated by pravin. i have a comcast connection with a speed of 50 mbps [which is max] and get the same output via ethernet however via wifi i see only 10 mbps. I have an Ipad air and iphone 6 which are connected. Not sure if this will lead to such a severe degradation in wifi speeds [as i dint see this issue with my previous comcast modem/router which i replaced with c3700]. Please suggest if i am missing something to retain my wifi speed to a reasonable limit.
      • DarrenM's avatar
        DarrenM
        Hello Rj007
        have you tried both wireless bands to see if this is the case on both the 5ghz and the 2.4ghz?
        DarrenM
  • 'I am using 105 mbps on Xfinity internet. On ethernet cable the speed comes close to 100 mbs, but on wifi its hardly 10 mbps.'
    Exactly the same problem...
